TwinTurbo.NET: Nissan 300ZX forum - Re: loose wire or break in wiring insulation causing a short
Subject Re: loose wire or break in wiring insulation causing a short
Posted by tanatastic on April 22, 2008 at 8:04 PM
  This message has been viewed 113 times.
In Reply To loose wire or break in wiring insulation causing a short posted by doug8867 on April 22, 2008 at 09:53 AM
Message :in the ignition switch. Vibrated itself into a position where it made contact or
:the exposed wire wasn't shorting itself out and worked fine. Now it's back in a
:position where it's shorting again. Probably need to check for continuity to the
:ignition switch and check the switch itself which will be a bit of a pain. :-(
ok thats kind of what i thought. now. how do i check those wire connections! im not too car savvy but i can follow directions. i need a write up on what to look for and how to get at it
